[ROM][GB][5.23.11]Das BAMF 2.0-5
2nd day on BAMF 2.0-6. Stock kernel but 245-1.2 clock. No problems. This thing is slick!
Sent from my rooted Bolt w/ tapatalk
I'm running preview 4 and it rocks! Thanks guys!
I did notice i don't have the bamf tool kit, download and reflash? Also noticed Pandora is slow between songs (really slow actually) will the mr2.5 radio leak fix this? Has any one seen better performance?
Special thanks to mclarryjr for help on a noob radio flash mistake!
glad its working out for you, I have my setting the same as you and have had no issues at all so far...
According to XDA you should have the BAMF toolkit with version 5 and 6, I would assume that would go for any versions in the 2.0 line... I would reflash. also, the toolkit looks like the setting ICON but its red and located in the app drawer. just letting you know, I wouldnt want you to reflash if not neccessary. :) also, I have not used the new radio yet, I have had zero issues with the MR2 radio and don't want to mess with perfection and take a chance on a 'leaked' radio, Ill let other try first and then report back. So far alot of people havent notice any significant improvement...
keep up with this thread to see what other people think about the new radio :) http://forum.androidcentral.com/thunderbolt-rooting-roms-hacks/94422-new-mr-2-5-radio-leak-3.html
Reactions: zero neck
Its titled bamf tool kit right? Ha also noticed no kernal manager app no biggy got it off the market.
If you're missing both of those, I would reflash completely, especially since you don't have the bamf toolkit it is very important
Sent from my ADR6400L using Tapatalk
Awesome dude, I'm glad you got everything worked out. You live and learn, and the more you learn the more you know, and the more you can help others out in this thread too :)
Is bamf 2.0-6 past preview 4 or is that a seperate critter all together?
Thanks
Thanks
2.0-6 is a completely different ROM. Preview 4 is Sense 3.0 based. 2.0-6 is Sense 2.1 based. They are 2 different ROMS....hope this helps. 2.0-6 is the latest 2.0 ROM and Preview 4 is the latest Sense 3.0 based rom from Das BAMF. 2.0-6 also has the REMIX version.
Reactions: NotJustAPhone
Kinda thought that, with the frenzy of gb wasn't sure. Thanks for the reply.
The toolkit was removed from preview 4 because it didn't work with the ROM.
Reactions: ssethv
Im back to 2.0-5... after giving -6 a try for 5 days, I just cant stand the green ring anymore and was getting better perfomance and slightly better battery from beta 5 in combonation with IMOS test 7 kernel :)
Same here. Not feeling the green ring or green button press highlights at all. Really like 2.0-5 remix, most things are working well, i ran fix permissions and it got alot of the fc's to go away, but now the weather animations aren't working inside the weather app - not such a big deal but they were nice to look at.
Anyway, switched from mr2 to 2.5 bc i was stuck on 3g somehow. 2.5 is so far working well.
And flashed imo's 3.1.1test3 kernel this afternoon for the fast charge capabilities. Apparently if you make a call tho it goes back to slow charge (haven't tried it yet).
Really like this rom, can't wait for a stable version of it, and fingers crossed for sense 3.
Imos test 7 has been the best I have used so far...
[GB Kernel] leanKernel: minimalistic kernel (3.0.1GB 6/7/11, v3.1.6cm7 6/17/11) - xda-developers
Reactions: ssethv
Crissy Doug
