[ROM][GB][5.23.11]Das BAMF 2.0-5
They're previews... work in progress until the final build of the rom is complete. As they work on the rom and make changes.. they have been releasing some previews of what it may look like in the end. Just so you know, the previews are full roms.. not add ons.. and need to be flashed like any other rom.
Preview 4 is on page 52: http://forum.androidcentral.com/thu...86004-rom-gb-5-23-11-das-bamf-2-0-5-a-52.html
Gotcha, thanks for the info. What rom is offered in the original post then? Is it known as Preview 1?
Sent from my ADR6400L using Tapatalk
The original post has das BAMF 2.0 beta 5. DB preview 4 is available through the link in the post that Cyber Warrior linked. I don't believe that the other previews were posted here. The xda thread had links to the earlier preview and is much more active than this thread.
Reactions: zero neck
Customize App Drawer/Quick Settings
Is there a way to customize the app drawer? Like add/remove tabs and the apps that are in those tabs (instead of having just having All, Recent, and Download)
Also, is there a way to change the quick settings in the notifications drop down like you could with dB < 2.0 by editing /system/customize/widgets.txt?
I don't believe that there is a way to edit the app drawer and the quick settings at this time hopefully after some updates these features might be added.
Cool, that's what I figured. Hope they do add that! Some phones do have the customize-able app drawer in their respective versions of GB, so I bet it will be added.
Im seem to be having really bad network connection these days. when i first got my phone my 4g connection was super fast and downloads were extremely fast. now it seems that google search almost never works adn downloads take really long. any suggestions on why? and how to fix? im running the bamf remix 1.7. and live in southern Cali. i should be having great 4g connection...Thanks!
Wiping cache and dalvik never hurts, i do it every once in a while. also, try and reboot your phone not just powering off.
Reactions: Bakafish
Reverted back to Froyo and....
After reading about all the bricked phones, I decided to revert back to Froyo. I accidentally ran an update from the PG05IMG.zip that was still on my sdcard after rooting my phone using the auto-root method found below. I guess I thought this was just the stock radio for Froyo. Anyways, I now no longer have root access (according to Titanium Backup and Rom Manager) and can't boot into clockwork. If i go to the bootloader it still says I have s-off. Any ideas on how to fix this?
http://forum.androidcentral.com/thu...unroot-windows-updated-5-20-w-mr1-update.html
Sounds like your still rooted if it shows s-off... I would delete the PB05IMG from your card, and reflash which ever radio you want and which ever ROM that will work with that radio... If I were you I would start from scratch (not that you have a choice)... just get that zip off your card...
after I zip any IMG i immediately use root explorer or my computer to put into a folder on my sd card and I keep it labeled too... I have all of the Radios on alot of different ROMs on my sd card in labeled folders, if I didn't do that I would forget what I am using ;)
Well I can't get into recovery to flash a ROM, I guess I could try flashing a different radio, but will that have any chances of bringing back my ability to get into recovery, because that's my real problem. Rom manager won't let me re-flash clockwork, saying I don't have the right permissions. Rom manager also gives me the same error if I try to reboot into recovery.
have you tried running fix permission from ROM manager, and do you have or use SuperUser app?
since neither one of us knows what IMG that was, i would guess it wasn't a radio... i wouldn't try to reroot your phone until last resort and if you do, you need to turn the S-off back to S-on and then start over... at least thats what I would do, BUT you may want to sit tight and see if anyone else adds to this conversation :)
Yeah, that IMG wasn't a radio, but I thought it was before I flashed it. I just realized it was the IMG that is used in the auto un-root guide that I already linked to. If you look at the guide, it shows a picture of a command prompt and one of the steps says, "The screen will eventually clear and you will see "checking PG05IMG.zip" Eventually, you will be asked: Do you want to start update?......" If I remember correctly, this rooting method flashed two of these PG05IMG.zip files. I think one was to perform some kind of downgrade and then the other was to then re-upgrade or whatever. Anyways, almost any command in ROM manager gives me the no root access error, even the fix permission thing. I downloaded SuperUser but ROM manager and titanium still couldn't find it after that, even after rebooting.
Sounds like you somewhat unrooted... I would just continue the process of unrooting, and rerooting, then starting from scratch...
But, like I said, You may want to wait for someone else to help out with this :)
K, that's what I figured. Any advice on continuing the unroot? Could I use the auto un-root even though it's "partially unrooted?" And last but not least, is this [Radio] [Leak] Official MR2 Radio 1.39.00.0508w, 0.01.69.0510w_3 - xda-developers GB radio stable, meaning it won't permanently brick? Or is that still up for debate?
I am not sure what point you are at in the unrooting process but i would 'think' that you would just need to turn the S-off to s-on and then start rooting again...
there is always the potential to brick your phone no matter what radio you are using... YES, some radio's, according to other forums, are more stable than others... BUT, even the most experienced developer or user can experience a bricked phone for no reason, especaially using the new gingerbread radio with a froyo based ROM (according to other forums)
us 5% of android users that like to play around with our phones are doing it at our own risk.. I have been using the MR2 radio with dasBAMF2.0-6 with no issues at all, but others are experiencing reboots and issues :)
one way that I keep up with all of this stuff is following certain people on twitter, hit me up via PM if you use twitter, and I can give you a bunch of developers to follow. it will keep you ahead of all this and up to date with alot of great android stuff
Damn... I had flashed dasBAMF2.0-6 and was having absolutely no problems either. It wasn't until I read all the hype about GB radio bricking devices that I decided to revert (which is now what's causing my problems :p ) Anyways, thanks for the help but I don't use twitter, so I'll just manually try to keep myself updated. Maybe someone else will know what's up before I get home from work to un-root/re-root.
I would wait too, the more advice the better, and good luck :)
thanks! so... how do i wipe the cache and dalvik? ... and how do i reboot? i dont see that option. sorry ...major noob.
RULE 1: first make a nandroid backup of your current settings just in case anything goes wrong.
then after making a nandroid backup and your phone turns back on there are 2 ways to boot into recovery, 1: you can open ROM manager and select 'reboot into recovery' or,
2: power down ur phone, the hold the volume down button and press the power button until the phone comes on, this will put you into clockworkmod recovery mode. once in there use the volume button to scroll down to 'wipe cache' and use the home button to select it, then scroll down again and reselect it (DO NOT SELECT " FULL DATA/CACHE WIPE... you will completely wipe your phone),
after wiping cache scroll down to 'advanced' and select, then scroll to 'wipe dalvik cache' and select. after that use the back button to go one menu back and select the top menu item 'reboot phone now'... you have just wiped cache and dalvik. don't get nervous when it takes your phone longer than usual to boot up, all its doing is rebiulding a fresh new cache for you :)
RAP25
