[ROM][GB][5.23.11]Das BAMF 2.0-5
Someone post the link again for GB preview 4 and 2.05-6 again. I can't seem to use the ones on the first page and can't find replacements.
So I haven't been on here in awhile. Are people still having problems with bricking from the GB ROMs? What's the newest radio I would need for GB?
This is the newest.
[Radio] [Leak] [6-16-11] MR2.5 Radio - 1.39.00.0528w, 0.01.69.0602w_1 - xda-developers
Neither mr2 or 2.5 seem to be bricking phones but you flash at your own risk.
@Notjustaphone - you asked in another thread if anyone noticed battery decrease with 2.5 right?
i dont notice anything different with 2.5 - except on mr2 i lost 4g for some reason (might not have been radio related at all) - so i switched to 2.5 and so far so good. 4g is consistently up, Fast gps locks, better battery life than froyo bamf rom-radio combos, the usual.
Man, i just had preview 3 few days ago and now there's a 4th already? On top of that, there's aready a Ginger Remix? Pretty hard to keep up nowadays.
Keep up the AWESOME work, guys. :D
Btw, any difference between preview 3 and 4?
i didnt stay on pre 3 long enough to tell the difference, but pre 4 is awesome - everything looks great. some stuff doesn't work tho so if you want a daily rom i would suggest bamf 2.0-5 or 2.0-6 remix.
How do I do a full data wipe?
if you're rooted and you have rom manager, you flash recovery first from the RM app, then you boot into recovery mode, navigate to wipe data/factory reset, and select with the home key, move down to yes on the list and select that with the home key.
Boot into clockwordmod and wipe data, wipe cache, and wipe Dalvik cache (under advanced). For step-by-step details (including screenshots), take a look at Cyber Warrior's stickied post on installing ROMs in the TBolt rooting subforum.
Reactions: zero neck
Apps and data have some kind of code (permissions) that makes them go together the right way, and if they don't go right sometimes you get fcs - fix permissions resets the connections between apps and their data so they'll go together again basically.
btw with bamf 2.0-5 i ran that and it changed 299 permissions.
also you can unlike posts after you've liked them.
Not feeling this heart icon that shows up for liking posts. I pretty much never need to heart something on AC forums.
This Like option will get interesting.
It's my understanding that Fix Permissions restores permissions to the default.
Personally, I would prefer a something like a smiley icon to a heart icon. Maybe a daggered heart for a dislike icon. :mad: But a Get Off My Lawn option would simply make my day.
So back on preview 4 since MR2.5 and still using it as my daily driver. That Sense 3.0 lockscreen is simply great.
ladakh
