Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed
Well, i have to start saying, joban you are a freaking god!!! thank you very much
Im having a really annoying issue, i installed Cyanogenmatt, and everything is working OK, but when phone is locked and i press a button, the screen turns into a dark grey color and lock screen doesnt comes up until i press anywhere in the screen... :( anybody else having this problem???! thanks
Try using a live wallpaper. My Thrive kept timing out before the screen came on if I used a non-live wallpaper.
wow ur stilling going the first kernel? the one without wifi and gyro?
HEHE!!! Oh God no I'm using the latest one you released I just started out with the first one and after trying a number of roms stuck with a version cause I got sick of reinstalling everything.
I use the Cyanogen Mod that you originally posted along with the new kernel. I keep my wifi on as well and I get a days use out of my phone easily, even with some fairly heavy usage.
Joban, you are the bomb! i never though i would ever find a rom for this phone, thanks a bunch! :D
UPDATE: Flashed the mod and OMG I f****** LOVE THIS!!!!!! THANK YOU JOBAN!!!!! :D no problems so far, phone works, wifi works, gonna test landscape.......
Reactions: joban
Thanks for you kernel but i can't send any file with bluetooth
Anyone can help me i'm using a lg thrive with sonymod
cvm,
Hows the sonymod? is it better than the one joban reccomended?
Tried the Ice cream theme but it seems my phone would not make it past the boot screen. It had a bad boot or something. Gonna try it again when I get time.
for the ics rom u need to wipe and then flash cm7 again and then reboot and then stright flash ics! and then u have flash my kernel after
thanks man! let me know if anything is not working! and please donate if u can, it means alot to me :)
Joban where do i get ics rom? XP this is the first rom ive ever flashed so idk
Ok thanks again man! your the best! :D mind if i friend you?
oh btw what do you use to overclock?
for overclocking u can just go into the cyanogenmod settings under preformance and then do w.e u like.
Weird... Okay... backing up and gonna try it now. :confused:
Ok sounds good, and unstable levels of mHz found?
umm i went to 786mhz and like 10mins it rebooted, but as i said every processor is different, so some many not even go to 700mhz and same may go 800+ so u gotta test yourself! and make sure u dont have set to reboot checked!
Ok got it, i wiped data and im reflashing cyanogenmmatv, am i going in the right direction?
Update: When i flash the mattv, can i flash the others as well? or do i have to reboot first?
Update: i reebooted, and now nothing pops up, black screen XP
Status
carlgrims
