Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.03 (Overclock, CM7 2.3.7 etc..) **WIFI FIXED
For those looking for a sleek/very usable rom, I do suggest the working Sony xperia themed rom, i'm on that right now and i love it, its got all that i was looking for in a rom. Just wish gyro was working....
does it have the lock screen lag too? and get the com.android.phone error as well?
well guys im working on the 2.6.35 kernel which i will try to make it work on all the rest p500 roms including andy's rom.
I'm not getting that com.android.phone error anymore after the first day. After leaving the phone alone and not overclocking,I haven't gotten it back.
u get that error when u reboot the phone or flash a new zip in the recovery, other than that u would get the error
There might be a fix for the gyro issue, joban check your pm
Actually, no I don't. Not since I first tried to overclock. Everyone's hardware is different I guess.
I didn't get a lockscreen lag, like CM7.1 that was originally posted, but I swaped back to it, i find it a little better performance wise, and i've never gotten the com.phone.whatever error, mines been smooth sailing, minus gyro.lol and gps and everything else has always been working out of the box or with a minor tweak.
I do miss the sms widget that came stock 2.2.2/i wouldn't mind making a "night" theme for stock sms, as i'm a little sick of the no blend colors (bit of a picky visual person). I'll see what i can get from any adw.launcher themes...
nvm I found a decent widget for my sms, its all good.
Reactions: joban
keep in mind guys every time u flash a new rom u need to wipe data maybe thats why only cm7 roms work because u never wiped your data.
ok guys i flashed cm7 without my kernel and landscape mode works, but not when i flash the kernel! odd cuz on 2.2 with my kernel works! any ideas? AND GUYS! VIDEO BEEN ADDED!!
Would the kernel being based off froyo be the issue? I'm probably way off base though.
Also, do you still get the gyro error with this ROM?
You read the steps that wrote? I wipe everything i can before i flash, and as for gyro, gyro doesnt work in any of those roms, easiest way to check flash +flash kernel, then open browser and tilt sideways, if nothing happens gyro doesn't work, and that happens for all of them.
And being based of 2.2 might be an issue, try using the source for the 2.3 version kernel from the p500 since the gyro from the works with our phone, so maybe that will make a difference. Or if theres a way to back up a few of those settings from a stock install of the p500 CM7 without the kernel flash then add those files back in after a flash of the kernel and see if it works. Worth a try anyways.
is it as fast as the first rom we've been flashing?
Overall it seems to be just as good, i haven't tried any of the overclocking and such, but as for the interface and using apps and such it was quite nice. Like i said i did notice a few lags when writing txts, and i didn't check quadrant scores so i couldn't tell you anything in that aspect. you may have to try it out yourself. Follow my earlier post though and you shouldn't have any issues.
Okay, I asked raeyne from xda about the gyro issue and he said a possible fix might be to swap the userspace daemon from /system/bin/ami304d, I attached my stock one for anyone who wants to try (it's inside the zip), he said if this doesn't work then it must have something to do with the kernel module. (Of course make a backup of your current one in case this doesn't work)
Status
sikkman859
