Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed
Joban have you gotten the wifi working yet?
This is almost too late to be useful, but I remedied the black screen issue on my phone by turning the screen-on animation ON in Cyanogen (or in this case, CosmicExperia) settings. It used to take an interaction with something on screen, such as an unlock slider, to get the screen to wake up but now it has only a half-second delay on average, with no inputs. Running CosmIcExperia on a p506 with a static wallpaper.
Also, it looks like a CM9 port is making steady progress.
[UNOFFICIAL][DEV/GEEKS-ONLY] Cyanogenmod 9 (Android 4.0.3)[BETA2] - xda-developers
yea the ICS has no lag at all on the lockscreen! but theres like 1 sec lag on cm7
Yea i already seen it, but im not gonna go develop my ics cuz i have no clue how to, and for the kernel im still studying it all
Oh ok, i thought it would have helped with the kernel. and btw what exploit do i use on super one click?
Alright so I've finally rooted my phone but weirdly when I tried to go Into recovery, I get a black screen. Any thoughts about that?
Sent from my LG-P505 using Tapatalk
How did you install cwm?
Oathkeeper, you probably flashed the new CWM for new baseband. The new cwm doesn't work. Seriously, get adb and fastboot set up on your computer. Download 5.0.2.0 cwm recovery from CWM website(for old baseband) and flash it manually. Once you learn adb and fastboot you can even manually root your phone(with virtually no problems at all)The commands you'll need to use once you have your phone connected to your computer and in fastboot mode are as follows.(Note this is assuming you have the cwm recovery located in C:\)
1. fastboot erase recovery
2. fastboot flash recovery C:\recovery.img
3. fastboot reboot
4. done
Then youll have the right cwm and you can boot into recovery like normal.
I do have both set up, I just never used any of them before. Well I used adb before but noy fb. Ok I will try and do it when I go home. Since I'm not supposed to have my phone. :D
I need the drivers for ADB and fastboot >_> crap.
OMG PLEAAASE HELP ME, I've been trying to install the drivers for fastboot but it can't get it! D: ive been trying for like an hour :P
Google is your friend young one.
These are the lg drivers you need. Also google adb and fastboot tutorials, they will help you get set up properly.
Stock Rom.rar
The archive is called stock rom because the files were in one of my stock rom folders and i didn't rename the archive.
Thanks bluntman but i just got it lol, i installed pda net and the drivers that were included did it ^_^ so now i believe i have 5.0.2.0 cwm installed. now another question, can i install TWRP recovery?
Oh and do i need ROM manager anymore? since i know how to flash it the beast way ^_^
Status
olivie
