Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed
Not sure, i only use CWM. But if TWRP have a recovery for our device then i would say so.
Edit - Reboot into recovery and fix permissions are still good functions to use with rom manager(If your on stock rom) Really is up to you if you think you are going to use it still.
is it still in beta?
Which one? the Full touch one? or the regular one? The regular one is out of beta im pretty sure.
Ok just got the new bandbase! Now fully working .35 rom! dudeee i been working on it alll dayy! more than 10 hours on this! i better see those donations!! :-$
Just donated. Embarrassed it's not more.
Thanks for the hard work. Looking forward to your next kernel
UPDATE: Getting start to compile my own rom from souce! You guys want the STOCK LG rom on 2.3.7? The stock one runs on 2.3.4. Or you just want CM7?
Cm7
Is the wifi issue a rom or kernel issue?
i have a question, does ur kernal work on the beta ics rom for the p500
joban i think we had this discussion before about roms. but we can collaborate again. id go with ease, if its easier to port than to build id go that rout. also cm7 is already optimized, then again the black screen issue.
My 2 cents. Only do it if you want to. I think rest of us will be fine with cm7.
Anything we can do to help get wifi working?
Don't fuss with a custom ROM yet, I'd hope that the kernel is the first priority :)
I dont think we should have a black screen issue with the .35 gingerbread kernel.(correct me if wrong joban).Also i would just work on getting the kernel 100% before anything else but whatever you feel like doing is cool. I'm running a skyrocket so none of this really affects me, but i gave my girlfriend my p505 so i'm glad that things are moving forward now so she can test all the roms and pick which one she likes best.
Joban ... Im in agreement about the kernel. There are a number of roms out there that wil suffice for now. With the introduction of ICS everyone will be moving in that direction. IMHO getting a killer kernel working should be the main goal with the ROM as a secondary. By the time you get a polished ROM going CM9 will probably be out and everyone will be asking you for that.
Reactions: LifesGoodPhoenix
Agreed
Status
godef
