Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed
UPDATE: The offical P505 bandbase doesnt fix the data! So idk what to do now!
Are you using this on GB or ICS? If its ICS there is a known issue with the P500 and the data issues.
I tried both and still no data! Im thinking its the rom! im gonna try old bandbase hack.
i think thats also the rom problem!
i got the cm7 mod working on my LG THRIVE, but when i try to flash jobans kernal to fix the problem, it doesnt work... It goes to the lg thrive logo and wont continue to the cm7 mod screen :(
Please help me, i need help on how to get Jobans Kernal to fix the color problem...
Thanks
Hey Joban try the perfect pesto ROM it seems to be the most developed one out there right now for the P500. its basically an updated ComsicExperia.
Thanks
you need to make sure you have the right rom and kernel combo. as joban hasnt released the .35 kernel that im aware of. if you flashed cm7 for .35 kernel and then flashed jobans .32 kernel it wont work.
Ok guys i think i fuked up my phone! I flashed back to the stock rom and im still getting no service on my phone. Then i upgraded to the offical gingerbread update and still getting no service!
Oh damn. i had a similar problem. My phone wasnt detecting my SIM card and i had to go back to stock :P
cant you try flashing the .35 kernal that ur making to fix it
yea i went back to stock from the kdz and still no service! Everything is stock now and still doesnt work! FUKK FUK! Seems like its time for a new phone?
joban before you give up see if you can get CWM on your phone. Then use it to wipe everything all the caches and stats. I had the same issue when I tried out one of the Perfect Pesto I tried reinstalling a new rom following the usual steps and it was borked up too so I wiped everything through CWM and reisntalled and that fixed it. I know the KDZ is supposed to rewrite everything but so far LG hasn't been the best, so it might be just an issue that they didnt clear something they should have.
Status
nettirb
