[ROM] [05.25.11] Das BAMF 1.7
Which download has no Sense?
All I really want is the dialer. The rest is useless to me, I think. Can I get a ROM setup like this?
Again, my appreciation to the developers. Was using my phone a lot today and noticed a problem where the screen would stay too dim when set on auto brightness. I come here to report and see that an update had been released to address the issue.
Thanks!
Reactions: nate44
I keep getting notifications about my SD card mounted read only. How's this problem fixed?
TboltMeatclaws-talkatap
That's a problem with your SD card, in all probability. I had the same problem, Verizon replaced it. Might want to back up your data to your computer and format it, see if that works.
I have a hunch the SD cards in the TB are junk and are going to start failing en masse sometime soon.
Not what I wanted to hear but oh well...I'll try the format tomorrow. What did you tell the Verizon Rep about your card?
Well it was within the first 14 days, so I made them give me a new card (after going through the usual factory reset song and dance), but when I first saw the error I posted a thread about it here-- http://forum.androidcentral.com/htc...-could-only-mounted-read-only.html#post805389
Some reports of failing cards there too. Last guy posted there saying a corrupted file, not sure how you'd track down a single corrupt file, but hopefully your card isn't toast!
how do we actually check the md5 of the radio?
i remember doing it in ADB when i rooted my phone but how do we do it now? what is the importance of this?
Anyone else noticed that when you press the VVM icon it goes to the messaging app and not the voicemail part? I am using the 1.6 NTE.
Remix is solid, I flashed this morning, the animations are a nice touch but my battery is still killing me. Nothing makes my battery any better no matter what I do so I'm just sucking it up
You'll like it. With 1.5 I was using Imoseyon's lean extreme kernal.
With 1.6 it likes the BAMF 4.4.3 kernal...snappy to say the least!!
Just my experience, of course.
I'm having an issue with 1.6.1, well, more like an annoyance than an issue.
I have 1.6.1 Remix with default old radio, desense, and volume button no wake.
I had it for 8 hours now and I'm in love with it.
I added Korean language keyboard and checked the box next to "Korean Keyboard"
Everything works fine... Korean works fine, English works fine.
But as soon as I restart my phone, the box next to "Korean Keyboard" in now unchecked.
So I have to check it again every time I restart.
Like I said, it's not an issue, but an annoyance. And I don't restart my phone that often anyway, but I just wanted to throw it out there.
THANKS BAMF TEAM!!!
THANKS BAMF TEAM!!!
Did you install the Korean Keyboard on your SD card? If so, try moving back to the internal storage of your phone. I had the same issue with the SwiftKey keyboard but after I moved the keyboard files back to the storage on the phone the problem went away.
Reactions: chunjaenim
Thanks!! that did the trick!!:D
I flashed in hboot the P file, checked the md5 it matches
Damn its on the htc screen for a good minute. Im on remix 1.5
marywilliams
