Easy to check.
Settings/About Phone/Software Information
Look at what it says under Baseband Version.
If it says 1.16.00.223r that is the factory radio.
If it ends in something else...it's the new radio.
Nate,
What SetCPU profile and settings are you using?
Also, when you make a change in the Toolkit under settings, does your phone reboot?
TIA
Hard to believe this phone could be running any better from 1.5, but it's noticeably snappier. The toolkit and call recorder are welcome additions as well. Thanks again!
Sent from my ADR6400L
I've noticed that since flashing to 1.6 and adding the radio firmware update that when I make a call I get a notice saying it can't find my LTE SIM card. However, the notice disappears after a couple seconds and the call goes through/works just fine, but the button that should be labeled 'end' is labeled 'cancel'. Thoughts?
