After a completly clean install I started geting force closes one after another, couldnt even send sms messages. 1.0.1 was more stable
Not sure what the problem could be but I am happy to know I am not the only one with this problem. I am going to try and install fully loaded now as I normaly installed the standard version.
I normaly add Adw launcher and widget locker to the mix along with advanced task killer, not sure if some of those are contributing to the problem. I just dont like the included launcher and lock screen in the rom.
I might like the fully loaded version better as I can live with touchwiz and I can also live without advanced task killer but widget locker is definety a must for me.
I would love to know if any of you who decided to wipe wipe wipe and reflash 1.0.2 from scratch are still getting force closes after a few hours of use?
I am not sure if I should just switch to ACE rom or just go back to "GASP" Eclair... I need my phone fully functional for 20 straight days for a trip I am going to in which I am going to need the camera, GPS and some video games (longass plane ride) working whenever I want to... I've flashed syndicate rom 1.0.1 three different times and each time I got a different problem. Images in the gallery were showing up as broken or problems while running spectral souls.
I thought 1.0.2 was going to be the answer to all my problems but it just got much, much worse.. should I just go to eclair? at least the frigging thing is stable
