[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Pkt_Lnt
yes, that old
Nov 6, 2011
798
194
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Ok, I went back to a nand of just the a10 test 3 and gapps with no other fixes applied. Flashed the cam fix 7 and all is fine. Here is the screen with the kernel. I know you did not update, so I think that is test 6 cam 3 before any other fixes?
kbp08tls
465
97
In other news, I seem to run into a weird issue of losing 3G after using airplane mode. What i mean is that after I turn airplane mode back on, 3g icon shows, but never turns blue. A ping test fails, even after radio toggle. I have to reboot to get it back.
Same here, but toggling data gets it back for me - no need for a complete reboot ;)
Pkt_Lnt
yes, that old
Nov 6, 2011
798
194
More testing. Used my clean a10.3 nand.
Flashed Drew's HydroKernel-ICS-Edition-v01pre4-unsigned.zip, then cm9.a10.camerafix7.zip and wifi is gone. Attached a screenshot with the greyed out button in the settings.
Clean nand again, flashed your hk-ICS-test6-kernel-cam3-signed.zip, then cm9.a10.camerafix7.zip and wifi is fine.
aaronrw
451
66
yeah test kernel 6 is the best so far, IMO....thanks for the updates I'm about to try this new camera.fix7 now
Xmb941
22
Loving This ROM To Death. I Switch Between Your CM7 & CM9 Daily.. I Just Love Both Of Them So I Choose Both... I Havent Found Any Bugs (Havent Checked) But Ill Start Looking.
res6jya6
115
5
Having problems staying connected to an open wifi network... WEP and WPA work fine, but the open network connects, let's me browse for a minute, and then no longer works. Says it is connected, but can't use data
ShadowEO
337
96
Just flashed it and everything's good in my end. I'm not getting any problems with wifi :) Swype also seems smoother, have yet to test the camera as I'm heading to bed though.
mkfryan
75
no new issues. forgot to wipe cache after applying had 3g and wifi issues rebooted to recovery cleared cache zero issues. thanks for the great work kraven.
vernotzy21
572
31
Super sick! Awesome.
Rendering in dolphin is slow keyboard seems to crawl as I type,extracted a zip file error on directory creation(couldn't reproduce) wifi spotty on me too
Touch click sounds come and go
FC's On a little bit of everything
Idk it kinda reminds me of on a old dos PC when you edit your config.sys file and your stack value is to low and you get a blue screen of death pounding a buffer overflow error into you eyeballs......just androids ALOT nicer about it:p
notebooko
59
9
Coming from CM7 with data2ext mod is there any way I can use the same partition to get my apps straight to CM9?
acromack
300
49
I tried that and it wasn't pretty. Best off just starting from scratch for a new version of android. Data2ext scripts do, however, work. I'm using one now.
notebooko
59
9
Dang it, I tried it too before you responded and ended up going into a bootloop. It's fixed now but too bad there isn't a way to do it. :(
wormy987123
flashaholic
Aug 31, 2011
393
29
I restored a backup of S2E with data using TB and then went thru the normal steps to set it up and haven't had any I'll effects as of yet on a clean install
Sent from my LS670 using Tapatalk 2
notebooko
59
9
So you had a backup with data2ext before and just used TB to make your apps in the old partition available again? Not exactly following what you did, sorry.
Sáenz
