Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed
Hey! I'm looking for the stock "free?" Navigator. I can't seem to find it and TT didn't back it up. Not sure if it was part of onother app. Its icon was just the arrow in blue. Any help would be appriciated. Thanks in advance.
hey! im using mmatt rom on my lg thrive, and i want to try gingercruzt 1.3. Should i just flash it in recovery or i have to do some sort of cleaning before flashing new rom?? thanks
also... where may i find lastest release of gingercruzt???
go to page 30. vipe_202 has a link posted...
i think i've given up on trying to get my bluetooth headset to work with my phone... i'll just use it on my ps3 i think. GingerCrust doesn't seem to wanna play nicely with bluetooth and phone app... also i think sonygen v1.2 was the last rom that i had that A2DP was working properishly.
I could get my headset to pair but not connect....I like this rom a lot, but need bluetooth for driving.
That's the one I'm running. I haven't tried sending files but I pair and connect with my car's BT every time I get in. Pretty smooth. I haven't tried the beta though.
alright guys i fixed the com.android.phone error in 2.3.7 roms, so im gonna make the rom with my kernel and with the fixes i made in a flash zip so you can just flash the rom and be good to go :)
can use this rom and someone can tell me if the bluetooth works( send/receive file?
[UNOFFICIAL][ROM][stable:6.5.8,testing:6.6.1] CyanogenMod 7.1.0 (Android 2.3.7) - xda-developers
I can send a file from my Windows 7 PC to my Thrive over BT using that ROM.
I cannot send a file from my phone to my PC using the same connection, though.
BT file transfers to Windows have always been problematic for me no matter what device I try, so I can't say for sure that there's a problem with how the ROM handles BT file transfers.
After applying your fix, go to Settings ->Wireless & Networks ->Mobile networks, and try to enable "Use only 2G networks".
First off.. did that work? I'd really like to be able to force 2G like I could on stock Froyo. :)
Second, do the errors come back now after a reboot? I can dependably make them appear by attempting to change that setting.
I had to make a permanent purchase of SQLite Editor after trying to enable 2G. Here's the fix for the errors, in case anyone gets stuck in the loop of FCs.
Could you still put up just a kernel package along side it with the fixes, i prefer finding a rom thats to my liking then flashing the kernel to it.
So does this mean we are getting an offical unoffical CM7 ROM :D
On a side note I think I found another minor issue last night. I tried loading a compass program to prove to the fiance the north is not up ( yeah she isn't good with directions at all). Anyways the compass program didn't work unless I had it one GPS mode and I have used the same program on stock with no issues.
Joban, i have a bug i think is caused by the kernel... when the phone is locked and i press any key it gets stuck in a black screen unless i use a live wallpaper (i can get out by touching on the screen). But that is not that bad, the most anoying bug is when i receive a call, the phone also gets stuck in the black screen and i have to guess where sliding bar is to pick up the call, and i can't see who is calling. This last bug happens regardless if im using a live wallpaper or not. thank you...
which rom ur running? and did it happen to all the roms u tried? how about 2.3.7?
Status
Abidalyy739
