Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed
Not be a jerk, but the recovery typen needs to move back to its thread please.
This thread named " Joban's Kernel 2.08" so my problems are legit.
I've complete full circle :(
Installed cwm recovery, flashed Joban's Kernel 2.08 on my "indian" version. Color and locked screen issue were gone. Then flashed CosmIcEXperia v3.5 and found myself back on square 1. It starts to boot, I do see spinning numbers but then it freezes. Now what?
Did you wipe everything before changing roms? Generally the first boot after rom flash can take a bit.
This kernel works on any P500 ROM? I can make flash AmonRA Recovery or has to be CWM only? With AmonRA work? What is the difference between the kernel and the franc, which is new? Thanks, I hope to answer
I have LG Optimus One P500, no 505... The SmartAssV2 will be fixed later?
What do I need to wipe except delvic? Could you pls walk me thru exact actions I need to make.
The current status is: CWM 3.....(didn't find newer img), so menu is short.
Can boot into recovery, fast_boot or emergency mode.
ADB is installed and ... didn't test after installing cwm :(
Thanks to all.
When you install a ROM you need to install the kernel after you install the ROM as the ROM has its own kernel and it will overwrite everything jobans kernel fixes.
I would recommend you look elsewhere for stuff for your phone the discussion here is mainly about us trying to get the P505/P506 working with the P500 ROMs and such. Asking questions here about the P500 is basically like taking instructions in english translating them into french and then translating them back to english. yeah you might figure out what your trying to do but why bother. There are a lot better resources out there for you to look into specifically for the P500. Not to be a jerk but we can't really help you with the P500 questions here.
Yes, I have updated the kernel: it fixes color issues, but not the start up freeze and reboot(watch dog I guess)...
More explicitly then, here is how I got it to work on the P505/Phoenix:
  1. Charge phone to completion.
  2. Download all files:
    • gingerbreak 1.2 apk
    • flash_image
    • CWM rar or zip that yields recovery.img
    • CosmicEXperiaROM 3.5 zip
    • Joban's Kernel 2.08 zip
    • GAPPS zip
    • ICS status bar fix from CosmicEXperia page
  3. Install the Gingerbreak APK and root the stock ROM using the instructions in the Gingerbreak thread here or on XDA.
  4. Confirm root success by running Superuser app.
  5. Copy recovery.img and flash_image files to the USB card.
  6. Install CWM 5 via ADB using flash_image and instructions on XDA forum. Be sure to accept Superuser prompt on the phone when you enter "su".
  7. Reboot into recovery using ADB command "reboot recovery"
  8. Use arrow keys and home key to perform a nandroid backup of stock.
  9. Reboot into stock Android and copy CosmicExperia3.5 zip, GAPPS zip, Joban's Kernel, and the ICS bar mod zip to the root of the SD card.
  10. Use ADB command "reboot recovery" to get to CWM.
  11. WIpe everything per ROM install instructions: cache, data, dalvik-cache, sd-ext
  12. Use the "install zip from sd card" option to flash CosmicEXperia ROM zip. Do not unzip or reboot.
  13. Use the "install zip from sd card" option to flash Joban's Kernel zip. Do not unzip or reboot.
  14. Use the "install zip from sd card" option to flash GAPPS zip. Do not unzip.
  15. Hit the back key and choose "Reboot device" to get into your new ROM. It will hang at the second LG screen for several minutes before proceeding to the boot animation.
  16. Allow the device a good 10 minutes to write files and settle before doing anything.
  17. Long press the power button and choose "Reboot" then "Recovery"
  18. Flash the ICS status bar mod zip. Do not unzip it.
  19. Reboot the device, set up your gmail account and enjoy the ROM!
  20. Once you get things set up to your liking, reboot into Recovery again and do a nandroid of your custom ROM where everything works.
gingerbreak 1.2 apk fails! I've mentioned above it can't root my phone anymore. It did do it before the "disaster".
You may want to look into reflashing your phone using the KDZ files specific to your phone this should allow you to get back to stock and try rooting again. Im not saying this is the ideal method but if all else fails.
I'd love to, but I can't get kdz for it. The only one i have and it kinda works is "indian". If you have other please send it to me.
Thanks.
look in the post for the fast boot fix ... I think joban put a link to it there if not just read all the posts I had to do it and thats how I got mine working.
Reactions: brberie
Here is update.
The only kernel with can find wireless network(AT&T, not WiFi) is the indian kdz. Everyone else can not! Don't know why. From this point on I'm able to load few roms including the latest linked with this thread. Because phone isn't working as a phone... With the indian, basically nothing works except phone, sms, accelerometer and wifi. MMS, GPS, camera, radio do not work. I'm thinking I need better KDZ to stat with. I found 3 kdz so far, but only indian works after flash.
Thank you.
Here is update.
Thank you.
plz upload kdz.
which one? I have few. The only one "indian" passes boot stage though.
I have this
LGP505AT-01-V10e-310-410-FEB-25-2011+0-DZ.dz
LGP506AT-01-V11e-310-410-MAR-05-2011+0-DZ.dz
my P505 work only with P506 firmware.
if you have another firmware plz upload.
Seems like i missed alot! whats going on here?
Update: Starting kernel .35 once again on a different computer to see how things go!
Reactions: Oathkeeper1212
Status
Crghjuygf
