[ROM][GB][5.23.11]Das BAMF 2.0-5
I haven't been able to get this thing to remain stable. Installed the rom, updated the radio, booted up and everything seemed fine. 20 seconds after booting it reboots on its own. Haven't been able to keep the thing active for more than 20 seconds until it reboots.
Ended up going back to the BAMF froyo version - have had no problems with reboots with that version.
Anyone have suggestions? (and yes, everything was wiped prior to loading the BAMF GB rom)
The reboots are normal after the initial install. It takes a bit for it to calm down. I'd say after three reboots or so, set the phone into airplane mode for a little while and then turn data back on. All should be well after that.
Reactions: NotJustAPhone
will give it a try. thanks.
the download link for 2.0-5 isnt working. I am rooting my phone right now to install this... please provide a working link :(
also- for the radio thing... so i flash bamf in cwm, then flash radio? right?
I got the rom from XDA but they are currently doing maintenance so you may have to wait
I flashed the rom, then flashed the radio. This time around i have not had any reboot issues
can someone repost the install file on multiupload or somethin and post link? :( this was the whole reason i just rooted my phone.
I would flash the radio first, then ROM. Don't forget to make your nandroid backup before you start flashing in case things get messy. Also being the biggest BAMF out there, I think Gingeritis is a more polished GB ROM at this point in time. I've read Butch will be releasing an update in the next few days, so I'll have to see which I prefer over the other when that happens. There also has been many kernel releases over the past week, and most are in consensus that Imoseyon's lean kernel 2.7.1 Test1 is the best performing overall. As newer releases haven't been charging properly.
so i got the rom from someone over on xda.. got it to install. flashed the radio ...
just one last problem. netflix isnt workin. says i need an update. >.<
Well it's just the patch to get it to work with the phone, shouldve been on the same page as the netflix app. But now I'm getting the same thing to...hmm. Anyone else getting an required update? Was working for me fine yesterday.
I'm really looking forward to an update soon. It seems Imoseyon has got the kinks worked out of his GB kernel with his latest release too. So if you're running 2.7, I recommend upgrading to his latest 2.8 version as soon as you can. Just remember to wipe caches twice at minimum, and charge to full then reset battery stats.
Reactions: zero neck
miyonfaga
