[ROM][GB][5.23.11]Das BAMF 2.0-5
I think I screwed something up here & need some insight. I was on Cubed ROM & switched back to the GB Bamf Remix 2.0 with the new radio that was leaked. Everything was fine, I tried Netflix, didn't work so I downloaded the full patch. I also wanted to flash a few other things (no wake volume keys & the screen off transitions), so while in recovery I flashed 3 things & now I can't get passed the splash screen ("the baddest!"). The OP says that boot will take a while after flashing the screen off transitions but it's been stuck for over 10 mins. I'm at work & can't connect to pc until I get home, any way around this?
i would leave it alone at least 15 - 20 min, and if it still doesnt go, pull the battery, wait a min or two, put it back, boot into recovery, restore your backup, and try to reflash all those things but maybe do them one at a time (i would flash the rom and kernel and make a backup, then flash mods etc afterwards).
or just flash everything at once except the transitions if that's the one you suspect is the problem.
Reactions: djinsydius
Here's the other kicker, I still have the radio on the root of my sd card, that will prevent me from getting into recovery correct?
yes. you have a sd card reader?
or, an old phone you can plug the sd card into, to erase that file first.
Yea that's what I figured, but I'm at work & so I wanted to see if there was another way around it. Thanks for your help Zero!
anyone else trying this with the new radio file? I heard today Bamf 3.0 is right around the corner though
Everything is working great.
you havin' any trouble with the voicemail?
i either don't get notification--but then
reboot phone--notification pops up
and then it won't go away
(menu>settings>call>clear voicemail notification (isn't an option)
apparently a lot of people are running into it.
It might be worth it just to take a look at not sure if it's ready to be a daily driver yet but it's fun to play with. I flashed the preview #2 and now going to try #3 since it looks like there have been some improvements.
Downloading now and will flash immediately....been on preview 2 for the last couple days, so will check this out.
Look's like the address bar has been fixed and now your able to use the agenda calendar widget which wasn't working for me on #2. I'm still unable to change my keyboard and have a few app's that FC but overall it's smooth and very impressive.
mattellis99
