[ROM][GB][5.23.11]Das BAMF 2.0-5
just finished flashing the new Radio and rebooting now....booted fine after rom flash but didn't have the radio done yet so I did that next. Lets see what happens.
Quick question. Probably been answered already, but I couldn't find the answer. If I wipe, flash this, then flash the new gb radio, then decide i want to go back to 1.7, can I just use my nandroid backup of 1.7, or will I need to flash an older radio manually?
You'll still need to flash the older radio back. The nandroid backups do not backup or replace the radio files.
Reactions: zero neck
Thanks for the quick response. Am I correct in assuming that I would need to flash the radio right away, before letting the phone boot up with the wrong radio? or will it boot and just not work correctly?
It will boot, but you'll get a whole bunch of errors and you won't get any data/voice service. I typically flash the radio first, and then install the rom, but you can do it in either order.
i flashed the rom, used adb to reboot into hboot then flashed the radio.
What exactly is the preview 3 file? Is it a pre-alpha type file, an Alpha or a Beta?
Just curious..everyone seems to enjoy running it, but I don't like installing until a "somewhat polished" version is out. (And I'm still nervous about the bricking...although I haven't seen any examples for a few weeks now). Thank you.
I think I've seen you on another forum before LOL
I think its just a preview of bamf 3.0 beta. To be honest it functions better than any other rom I've used on my TB. No hiccups, no random reboots. Been running it about 24 hours now.
I'm baaaaa-ack!
After multiple computer issues and limping around with my laptop (which is also dying), I can work at normal speed with a new computer.
Anyway, here is Preview 4:
http://bamf.neuromancy.net/roms/bamf_sense3_pr4.zip
9d00452bcb234cc5764b86be315c5f9c bamf_sense3_pr4.zip
Like the other previews, there is no support. These are neither alpha, nor beta. They may be daily drivers, or they may be the last nail in your coffin. We aren't half assing this port, so its taking much, much longer than other Sense 3 ports. Please do not mirror!!!
PR4
Many more fixes from erishasnobattery
New skins (check out Burgundy!).
Proper scenes previews, but still not sized right.
Fixed mail account selection
All new Sense 3 wallpapers
There are actual widgets shown by default on a clean install :D
Wipe is recommended this time.
Warning: Don't use scenes from HTC Hub!
I'm baaaaa-ack!
PR4
Damn! 4minutes ago, been browsing! Now I'm in line for DL. Thanks again for all you do AD!!
Hey adranalyne, for some reason my preview 3 didn't have htc hub? I can't find it, want to suggest anything?
I'm baaaaa-ack!
Nice! :D
I'm baaaaa-ack!
PR4
Hey guys, thanks for all you do. I'm personally waiting for a release build, so I'm happy I hear Y'all are still pushing forward.
StarLight88
