[ROM][GB][5.23.11]Das BAMF 2.0-5
OK, I've waited 10 to 15 minutes and the rom only shows the notification bar and the wallpaper. Would anyone suggest a battery pull???? How long did you guys have to wait for BAMF beta 4 to load up?? Help please, I wanna be cool like you guys!!
You have to wait a bit for your screen to load.....did you do the full data wipe like it mentions on page 1 of OP??? Make sure you clear out all the cache to then just be patient it takes a while the first time.
Reactions: FedexMike
Just curious anyone else without data (1x, 3G, 4G) I have not had any data since last night, and still have no data this morning......This is begining to get super frustrating, I am going to call VZ CS here in a little bit love this phone but lord....the network is proving to be VERY UNSTABLE.
I didn't wait long. Should I wait longer???? And could someone link me to the exact radio. To be clear all I need to do is flash the radio then the Rom??? Thank in advance!!!
Exact radio is on the first page under Gingerbread Alpha...it does not matter what order you flash, if you flash the ROM first you just won't have service until you flash the Radio
@porkshanker, dude if i could shake your hand and buy you your drink of choice i freakin would. Thanks a ton. It was simple instructions right to the point. I'm rockin gb right now thanks to you.
I can not get the new gingerbread radio to install and have no idea why. I downloaded it from the link on xda and everytime I get into hboot it just give me an error and refuses to install. Anyone else have this issue?
Up and running. Under Wireless & Networks my Mobile data box was unchecked for some reason, re-checked and am good to go.
Download from the link on page 1 of this post, It should save as a .zip file named PG05IMG. Place that file onto the root of yourr SD card (Phone must be in Disk Drive Mode) Get into hboot and it should automatically update. I used the link on page one of OP and it worked fine.
Ah I got it now. I left it in my downloads folder instead of just putting it onto the root of the SD. It is flashing now. Hope all goes well.
HELP! I have it set as a disk drive, but I can't see it on My Computer. I'm trying to flash the new radio, but can't since it won't show up on my computer
So how do I flash the GB radio? Never flashed a new radio before
DL the radio file and put it on the root of your SD. Then boot into hboot. Power down then power up holding volume up and power. It will automatically flash the file. When it asks for update. Select yes. Your all done!
Tbolt meatclaws-talkatap
Reactions: mfancy
Thanks! Any suggestions on why I can't see it as a disk drive under My Computer?
Just a Question.....
So I have flashed the Radio and put this ROM on 2 times but can never get it to show the keyboard to enter anything.... both were installs with both the delvik and full wipes done???? im a bit lost about this.
Sorry in advance for this question but im very much a noob. I'm a little confused as to which version of the rom i should start with... There's so many different versions in the original post and im not sure as to which one i should initially install? Please help...
Did you do a full data wipe like the OP suggested on page 1? If not try that make sure most recent ROM/Update for rom is flashed 2.0-4.01
No problem, page 1 of OP most current is 2.0-4.01, also make sure you flash the gingerbread alpha radio on the same page. Good luck.
Reactions: MyDroid79
help.. 2.0-4.01 not loading. Gets stuck on live wall paper nothing else loads??? No unlock screen, no icons, nothing.... Just a blank live wallpaper page and battery notification thats it. Thanks.
Did you clear cache/Dalvik/data?? If not boot into recovery do all three like the op suggest on pg.1 and reflash. Give it some time 10min or so takes awhile to go through everything.
I cleared all data. I went ahead and restored back to foyo... Which three should i flash and in what order? the first two under downloads then the radio or the second three under previous versions then the radio?
I like this forum WAY better. Seems like the guys on XDA are a bunch of guys that aren't getting laid. Everyone seems to be a no it all (but don't actually know anything). Thanks everyone, and thanks Android Central!!!!!!!!
EnigmaDragon
