bigdonpaul
- Apr 28, 2011
- 90
- 0
- 0
Does the radio have to be flashed first? The rom loads and shows the background, but it wont load past that.
I went from BAMF 1.63 to version 2.0-4.01 earlier today, and I've been pulling my hair out since. No service, gapps is crashing. ROM Manager is crashing even after a fresh dowload, and a bunch of other things not working. This version isn't for the noob, that's for sure. But it looks really really nice and the Sense 3.0 is sweet. (two thumbs up)
Hey buddy, only download the Alpha Gingerbread radio. Download the bamf 4.0.1. put the two downloads on the root of your sd card. Flash the radio in hboot. (hboot= power down, volume down key+power button, press up for yes, then reboot) Delete the radio from your sd card. Power down again. Volume down+Power button. select recovery. find the bamf 4.0.1 on sd and select. Let it do its thing then reboot. You should be golden.
This is from earlier, I had the same problem.
What folder does the radio go in?
My phone is charging really slowly since I flashed the new Rom. Is this common?
Sent from my ADR6400L using Tapatalk
Yeah the kernel doesn't support the fast charge yet. forgetful said if you reboot while charging it will speed up.
Sorry in advance for this question but im very much a noob. I'm a little confused as to which version of the rom i should start with... There's so many different versions in the original post and im not sure as to which one i should initially install? Please help...
Flash imos 2.5.3test7 kernel from here: [Kernel] [GB] leanKernel: minimalistic kernel (2.5.4test1 5/21/11, v2.5.2cm7 5/17/11) - xda-developers
Clear cache and dalvik first then flash. It should help with the slow charging issues. Unfortunately after I flashed this kernel I experienced 3 reboots right away but fixed that by pulling the battery for 10 minutes. I also just experienced not being able to answer a phone call, it forced closed on me right away. Other people have also experienced this problem over at xda. I think they just wiped everything and reflashed and the phone force close was fixed. The phone does charge a lot faster though!
Hot damn! Every time I update something im already behind a version! Just like that best buy commercial lol. Let us know if your battery temp stays over 100. I know others experienced that prob with the slow lte download patch before it was added to a kernel (2.5.4test1).
On another note I just tried a few test calls from my fiancee's phone to mine and I was able to answer without a problem.
So far, so good. Running smoothly and using the web browser with LTE. Unplugged from the charger about twenty minutes ago, and battery temp is just under 100 degrees (was over 100 while charging).
Good to here. Not sure if I need to update to the 2.5.4test1 kernel since I'm not in a 4G area anyways, unless there is something else within the new kernel that makes it worth it.
EDIT: How is your wifi stability with the new kernel? Since I've flashed the 2.5.3test7 kernel my wifi keeps going in and out. First time its done this.
can anyone explain to me why i cant change my sd card to read like a disk drive anymore?
So just to clarify... I am currently running BAMF 1.6.3 remix with the new RUU radio... Do I flash this ROM first and then update the radio after... I tried to apply the new GB radio in HBOOT but then I wasn't able to use CWM or even work it though HBOOT... Im quessing I need to remove the image from the root after is is installed? any help would be great thanks
ALSO... what do you guys think about this ROM compared to 1.6.3? just curious
