Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed
@joban
How much you think you'll need to change? Hard or easy?
using CyanogenMod 7.1.0 / 6.5.8.. getting a black screen after phone goes into standby and unlocking screen
anyway... should i be using a diff build of the rom ?
What you are describing is probably the lock screen issue. Switch to a live wallpaper, see if it helps. There really is no tried and true fix for this though some ROM do better than others.
LG is part of the open handset alliance... has anyone asked them for the driver source code?
Dear Joban ur Epic
The ICS rom for LG p500 is released on xda-dev.. Please provide the kernel which can work with it.. as current kernel 2.08 does not work with the new ics rom . LG phoenix is not able to use that rom... All help is much appreciated and certainly donations will be made to make ur effort is continued..
Dear Joban ur Epic
You need to go back a page and read. Our phones haven't been updated. So no kernel exists to work with new baseband or. 35 kernel required Roms. Joban is TRYING to come up with something, so just sit back and pray.
Got a problem, I installed cyanogenmod7 and fallowed the steps but my phone reaches the cyanogenmod7 logo with the swirling arrow and then it just stops spinning and I have no clue what to do now.
possible bad flash. make sure to factory reset, wipe cashe(s). re-flash, may try a diff rom. make sure you get one that is old baseband and for a .32 kernel. do be patient, first boot can take awhile.
UPDATE: First try, the phone booted the boot animation and shut down those small warning text! Something close to when u get the com.android.phone error when it restarts it self. IDK whats the wrong but need to do more work! And its hard because our kernel is 2.32.9 and francos is 2.3.14 (i think cuz i forgot =D but its differnet)
Wish I could offer more than just encouragement. Good luck and keep at it.
best of luck joban ... im with thrivin on this I wish I could offer help but I haven't got a clue what you need in order to build a kernel.
youll get it. i have faith.
as a suggestion, you could ask ASPEE from xda for some advice. he at least responds.
Hi guys!
I think I need help:( Could any of you say: if I'll use the original P500 ROM and P505 kernel compiled from LG source will it work? And if so can anybody help me comple that one? Main reason is to get russian locale on my phone.
Sure it would work. But what is required to make it happen is WAY above anyone here.(I could be wrong)
You need to ask in a developer thread.
Hi guys!
I dont get what ur asking for? This is compiled from LG source!
Well when I get my phone back from been tagged I'll try again. Hopefully it won't brick again...
Joban, I was using your kernel with 3 or 4 custom ROMs and 1 stock ROM from p500 - all I've got is a messed colours or "overheating.." or some other strange things. With Cyanogen mods everything is great! I just ask you to compile the kernel without extra stuff from Cyanogen (just straight from LG sources http://www.lg.com/global/support/opensource/opensource-detail.jsp)/ I wanna try it with international stock LG ROM. Can you do this favor?;) With great respect and many thanxx!!:D
Status
joshchild106
