[ROM][GB][5.23.11]Das BAMF 2.0-5
phewww finally running gingerbamf .. i swear this is definitely worth the troubles i went through today, and finally Netflix !!! :) going to go enjoy my phone now, thanks everybody for the help ..and for everybody having problems go to [ROM][GB][5.23.11]Das BAMF 2.0-5 - xda-developers < that thread is moving extremely fast
Too fast for me, that's why I like it here.
Almost 170,000 views in under a week. Pretty impressive
ok, so got everything done. Rebooted and now it just sits on facotry HTC wallpaper screen with notification only showing battery and not connected to network. I cannot do anything. any help?
i flashed the first set that was given, now i am going to try another one. now since i cant do anything how do i get the files on my sd card?
Download the radio file to your computer.
Connect phone and enable disk drive mode.
Copy radio file to the root directory of the SD card.
Flash radio in hboot as you did with prior radio file.
the phone will not let me do anything. it just boots and nothing works...adb command for it?
Did you make a backup in recovery before you flashed? Power down phone, then hold power and volume down buttons to recover.
when i get in bootloader, i choose not to install the old radio that didnt work then it just reboots phone. so frustrating.
automatically starts to upload the pg0 zip file. changed radios and still nothing.
yeah you wont be able to get into recovery with that on your sd card. Do you have an sd card reader you can use to remove it? What radio file did you put on there before you flashed the rom?
md5 - 3e2a44aee2d11bcc300a622d6103fe0c
gugino
