Clockwork flashable Froyo EB01 with root and busybox
Status
Not open for further replies.
I have a question regarding backups. I use Titanium backup to backup my apps. I am planning to load EB01 as soon as the download finishes. Will I be able to restore my apps and/or app data once I am running Froyo? I have a couple apps that are a pain to set up. I am currently on DL28.
Thanks.
texts
can anyone tell me why my txt msg doesnt wrk? the texts i send are blank and i dont rcv any texts at all
can you flash the EB01 modem over a DJ05 modem? or do you HAVE to be flashed with DL09?
ok it says s:1500.04 .di01
im not sure how to do it with odin any suggestions where i can read up on that?
May want to get input from one of the more experienced people as I have not read anything about going to EB01 from DI01. Not sure if you have to go to a stock DL09 first or not. Sorry.
Reactions: Hausman
I tried to use the Sammy Keyboard from DL30 SC 1.0 and I am getting a force close. Does anyone know where to get a compatible EB01 Sammy keyboard?
Something kept me from doing the DL30 last night. Tonight I got brave again and found this topic... and it was SOOO easy to do. No trouble at all, and now I have Froyo. Thanks for releasing this. I am curious though, when Verizon does a maintenance update, will I see it, or am I now stuck doing these 'manual' updates?
I was running Baseband S:1500.04.V.EA28
Kernel: 2.6.29
Firmware 2.1-update 1.
Everything went perfect. No troubles at all. I did take a moment and refreshed my samsung drivers from their website for my Win 7 machine before I started. I don't know if this helped or not.
you'll be fine as long as you flash the EB01 modem first, than superclean and wipe wipe wipe.
DL09 is not necessary as an intermediate step.
Hello.
Can anyone tell me the difference between EB01 and debloated EB01?
Also, Adrynalyne, can wireless tether be used with your EB01?
Status
HandsomeZinck
